Removing a Stuck Gimbal Bearing
Wekims
I did a search here but couldn't find anything on pulling a stuck/rusted gimbal bearing. Tried a bearing puller attached to a slide hammer (couldn't find a 3 jaw puller that would fit). I'm soaking it in PB Blaster and will try the hammer again.<br /><br />Any other advice?
crazy charlie
Re: Removing a Stuck Gimbal Bearing
Keep soaking it and you will need a bigger puller.Charlie
Wekims
Is a puller better than a slide hammer? Looks like I have to fabricate a puller setup since the hub is round and no place to screw the bolt into to pull the bearing.
hondon
What are you working on ?Some old Mercruisers ,there is a snap ring to pull.Sound familiar?
Wekims
It's a OMC Cobra. It's just stuck on from water rust from a leaking bellows. I'm drilling holes in the gimbal bearing and soaking it in PB Blaster. Tomorrow's the day I give it the all out effort with a slide hammer again.
Seaboo2
I used a 3 jaw puller built into a (big) slide hammer (borrowed from an auto repair shop).
