Removing scuff marks from bow.
Cruzomatic
Was on the lake this past weekend and my buddy wasn't able to save my new boat from a scuff mark on the bow from the dock as the water was way choppy. Any suggestions on how to remove it? Was thinking there may be a wax or cleaner that could work wonders. <br /><br />Thanks,,,,,
Re: Removing scuff marks from bow.
Ayuh,...... It's called Elbow Grease.......... :D ;)
crazy charlie
Try a liquid color restorer or liquid compound.If it can be removed without leaving any marks,these will do it.A Mr.Clean magic eraser does a good job too.
Texasmark
If that doesn't work, I had a boat repaired once and the service facility used matching jellcoat in a sray gun to cover it......but I'd try rubbing first as the spray is hard to get on without being noticed.<br /><br />Mark
