Removing Side Glass from Bayliner
Jango
I am in the process of removing the side glass from my 88 Bayliner. My problem is removing the Aluminum Frame from around the glass. I would like to reinstall the Aluminun around the windshield to better finish the job. I can not find a release agent to seperate the Alum from the Glass. Have tried Lacquer Thinner, HCL, and 3M Release Agent. Any Ideas? Thanks.
Jango
Re: Removing Side Glass from Bayliner
Found a way to solve the problem. Used Heat. I carefully heated both sides of the Alum. frame with a propane torch, moving the torch constantly so as to not create a hot spot and by hand, immediately pulled the Alum. and glass apart. <br />I didn't want to destroy the glass in case at a later date sold the Boat.
bayshiner
Do You Have A Capri ? Why Would Want To Remove The Glass? On M Y Capri I Think They Are A Little Confining But Great On Early Morning Or Fall Runs. Bayshiner
July 23rd, 2002, 08:36 AM
Ayuh,... Welcome Aboard Bayshiner.... Are you Really expecting an answer,..??
