Repair hole in fiberglass stringer
erikpn
It's a foam filled fiberglass stringer. Looks like the previous owner attached a bar or something to the stringers in this boat, leaving a 1" hole in two stringers where they mounted it. How do I fill it? The foam is damp, but not saturated. I was thinking the best option is to glass it. But I can't get access to the glass from the inside of the stringer, where its full of foam. Should I just grind it down and glass over the outside?
Re: Repair hole in fiberglass stringer
Got pictures of it?
pauloman
one option is dissolve the foam with solvent and then fill with an epoxy that bonds to wet or damp surfaces - with sand mixed in to provide bulk and mass
ondarvr
Just do a quick patch on the outside. All you are trying to do stop more water from getting in.
