Replace 4.3 Mercruiser w/5.0 (Ford) Volvo
tunacious
What would it take to replace a 1999 4.3 Mercruiser with a 5.0 (1996) OMC/Volvo. This is a Ford 302 block. I dont want to mees with the outdrive. Thanks
Haut Medoc
Re: Replace 4.3 Mercruiser w/5.0 (Ford) Volvo
Nope, you will have to stick with a GM or do some expensive changes........;)
John_S
"5.0 (1996) OMC/Volvo. This is a Ford 302 "
I must say, I don't know volvos, but thought ford was out of the marine engine business, before that. Are you sure of the year and engine make? Is distributer in front or back of engine?
Even if it is a GM 5.0L, not sure its worth the effort. Might as well go for a 5.7L. A 4.3 vortec vs 305 non-vortec, not much, if any, improvement.
Ayuh,....... I Agree,......
And,....
The Issues with trying to bolt a Volvo dressed motor up to a Mercruiser drive with be about Impossible........
John, 1996 was the last year Volvo used the Ford engines. It was a holdover of the Volvo/OMC joint venture. As soon as Volvo bought out OMC completely, they dropped the Fords.
John_S
Thanks Don, I know them just a tiny bit better, now ;)
