Replace Alpha One shift cable?
cadunkle
I'm doing ym bellows and shift cable on my '89 Alpha One. I can't get the old shift cable nut loose. I've been hitting it from both sides with MAPP gas and PB Blaster for a while and it won't budge. When I put the socket on it feels like it's gonna strip the head on the nut/fitting. Anyone have a trick to get these out if they're stuck real good? It's a pain because there's not much room to get any tools in there.
cadunkle
Re: Replace Alpha One shift cable?
Nevermind, drilled it out from the backside and got the rest out with an extractor.
Bt Doctur
Better download the manual because there is no nut on the shift cable.What you precieve as a nut is part of the shift cable
cadunkle
Gee, ya think? Well it isn't a problem because it's out and the new cable is ready to go in as soon as I blast and paint the bellhousing. Oh, and I do have a shop manual for my engine and outdrive. Replace "nut" with "hex" or "fitting" if it makes you feel better.
sikpupy
Damn, just looking for some shift cable info, what the h*ll did I walk into?
sikpupy
Yea, I know, replaced one before but it has been a while. Wanted to refresh my memory and found this thread. Uhm, yea, okay........lol.
Thanks, will check out the link.
Bt Doctur
It IS NOT a nut, it`s part of the cable , It turns with the cable upon removal.
