Replaced stater and rectifier, still no spark in one cyl
Cady8special
I’m at a loss here. Just picked up a boat with 40hp merc 3 cyl 4 stroke. It bogged under load, but did get up on plane once. Any time I gave gas after that it would slow or die. Batteries weren’t charging either, same voltage running or not. So I got a new stater and regulator/rectifier and it still seems like I’m not getting spark in the second cyl. When I spray gas in cyl 1 or 3 it bogs. Cyl 2 there’s almost no affect by it. Same if I cover the manifold and cut the air- cyl 1 and 3 slow down, cyl 2 is not really affected. What else could be causing this issue? It’s not plugs or wires I tested that.
Cady8special
What ?
"seems like I’m not getting spark"
Have you actually tested for spark?
Model/serial number
Serial 0t42660
I tested spark a few days ago and it wouldn’t jump a 30 kilo gap while the #1 cyl would. Today I put a timing light on, and all 3 make have spark according to the timing light. But when it’s at idle on muffs and I spray gas into the manifold, it Boggs on #1 and 3 but almost no affect on 2. Same if I cover the manifold and starve it for air. 1 and 3 bog, 2 not so much
gpfishingdude
Might have to run a better ground to the coils for those cylinders. That was what I had to do to get spark on two out of four on mine.
Cady8special
It just ran good for about 10 seconds- good throttle response. then back to running crappy. So it’s some kind of intermittent issue
If the spark would not jump a .030 gap, there is the issue.
I would swap your # 1 coil assembly with your #2 coil assembly.
Then check for spark again.
If the issue moved to #1 cylinder, then you need a new coil.
I'm pretty sure the plug wire is part of the coil, so don't try pulling them apart.
Cady8special
Not a .30 gap- about a one inch gap on the spark tester. 30 kilovolt gap
Cady8special
Messing with carbs now. Evened out the suction on each carb -they all draw the same amount of air in now. Before it was like cyl 1 was doing all the work, now it’s more even, but still bad throttle response
Cady8special
Just water tested after getting carbs synced. Idles great, bogs at 2k rpm. Nothing I can do. Compression is good, spark is good, carbs seem good.
