Replacement distributor 153ci mercruiser
57whitehouse
I wanted to find an all inclusive distributor and do away with external coil. Want electronic ignition with it of coarse. $450 is about the cheapest I can find. Any ideas where to find one cheaper?
1966 mercruiser 153ci 2.5L
You are looking for a marine distributor than meets SAE J1171 that has an integral coil?
There is only one company and that is DUI.
No one else wanted to pay the royalties for the patent.
ROY WILLIAMS
I was the Pertronix igniter the auto / boat engines replaced it of the ignition distributor did the Pertronix igniter ... back in the old decades ignition switch ...
I was the ignition coil updated it and the Pertronix igniter ..
look up the youtube of the Pertronix ,,, engines of the ignition switch changed it ..
