replacement fuel pump part number
J JACKSON
I have a 1988 70hp E70ELCCA and I need a replacement fuel pump it has a VRO pump now but the housing is cracked and I can't keep the screws tight so it won't leak, I have came up part number 18-7353. Will this work?
Daviet
Re: replacement fuel pump part number
When I look up that part number, it says it's for a 20-30 hp engine.
I think you need a larger volume pump, something like a 438559.
Just order a pump for the 1983 model 70 HP or a 3 cylinder 65 HP commercial model for 1990's
