rolmops
- Joined
- Feb 24, 2002
- Messages
- 5,736
This thread is sort of a continuation of a coosa discussion.
I will try to make this a log of transom rebuilding
So after deciding not to use coosa, the next logical choice is marine grade plywood. I considered types of pvc and polyethylene but those did not really appeal to me. The decision to use marine plywood is mostly bases on me having build wooden transoms on 4 aluminum boats. A starcraft Holiday, an eighteen foot Sylvan, A 19 foot Starcraft Islander and a 22 foot Islander.
The previous 22 foot Islander transom was build during covid and having to take care full time of my ailing wife. shortcuts were taken and time and material saving measures were also taken. Most of it based on the thought that this rig is a trailered boat and will never be in the water in a slip for the season. I did not even properly seal the wood but put on six layers of deck paint instead and the plywood itself tuned out to be some soft junk.
However, things changed and the boat ended up in a slip for most of the season with me worrying about rot and leaks. Next season she will be back in a slip. It is just so much easier.
I will be replacing that transom with a new one that will be properly built and does not require much maintenance.
Yesterday I went out and bought 2 3/4 inch thick 4 by 8 foot 10 ply dense AA marine plywood. The density is important so there are no imperfections inside the wood and the glue used is impervious to water. The transom will be 1.5 inches thick.
Money wise, compared to coosa board goes like this. A 4 by 8 1.5 inch thick coosa 20 grade board costs $562 before shipping (from FL to NY). coosa 26 grade is more like $680. The marine plywood 2 3/4 inch boards were $426 without shipping cost because I picked them up 5 miles from home.
So far so good.
Next comes the process of gluing the boards together and here comes my first question. How do you good people prepare the wood for gluing and what type of glue do you use. Please let me know so I can use your experience and prevent mistakes.
So far so good.
