Replacing Exhaust Hose
ktmrider
Volvo Penta and SX drive. 5.0 GL PWTR
Currently, the lower exhaust hose is leaking at normal operating temperature about 2500 rpm's.
It looks like, in order to replace this lower hose, I would need to remove the upper exhaust hose coming from the risers first then the upper exhaust pipe. At that point, I would have access to the lower hose?
http://www.marinepartsexpress.com/V...7GSPWTR/INTAKE AND EXHAUST SYSTEM/Exhaust.pdf
3852742 part number
Re: Replacing Exhaust Hose
Ayuh,... You've got the Idea....
