Replacing fuel/water seperator on Mercruiser 4.3 L MPI
gt2003
Not too difficult but I need to know if I should fill filter with fresh fuel before I put it on. I've tentatively sold the boat and it will be in the process of being "de-winterized" soon. I've got a Moeller # 033323-10. Should that do the trick? Thanks
Ayuh,.... The more you can pre-fill the filter, the easier it is for the fuel pump to reprime the system,.....
Necessary, probably not, beneficial, probably so,....
gt2003
Thanks Bondo. Will be completing this task this weekend.
