Replacing prop after service
bako88fan
Hi all. I removed my prop so it could be repaired. It had a couple of nicks and needed to be balanced. I have a locking key for it, similar to a lug lock on a custom wheel. I didn't notice when I pulled the prop off how tight the prop and locking nut was. Here us my question. I replaced my prop and tightened the nut. I didn't want to torque it too much because I didn't want to affect the spin. However if I grab my prop and pull aft, there is a small amount of slip or play. I moored to a slip tonight (we are on vacation in Bullhead City) and before I head out for a week on the river I'd like to make sure the play/slip in the prop won't burn up a bearing or an engine.
2004 Sea Ray Bowrider 220 Signature
5.7L Mercruiser
3 blade prop (not sure of diameter, nor pitch)
Re: Replacing prop after service
Ayuh,... The Nut, should be tightened to 50ft.lbs...
'n, Yes, the propshaft moves fore, 'n aft, 'bout 1/8th inch...
bako88fan
Looks like I did it right then. Thanks for the help!
Ayuh,... Hopefully, ya slathered the propshaft with Grease, before ya slid it on...
