Replacing steering cable, numbers on old cable are:
craigvalk
Hi guys. Just picked up a nice little 88 17 ft Renken bowrider with a 3.0 OMC sterndrive.... Needs a steering cable though.
My question is this... I took the numbers off the existing cable ( still installed in boat) figuring I could match it up pretty easily.
The numbers on the cable are
Morse E360019
166 IN
3945
Now I know that Teleflex has the replacement cable for the 360019, right here on I boats. My question is on the length, I am thinking that the "166 IN" is inches which works out to 13.8 feet or so, which I guess means a 14 ft cable.
I know I should have measured the boat and there is a formula to determine the cable needed but I was pressed for time, the boat is up at the lake and I am not, so I just scratched down the numbers and here I am.
Anyone able to answer this for me? Much appreciated....
Craig
Texasmark
Re: Replacing steering cable, numbers on old cable are:
If the old cable fit the new one should too. The 166 at the end of the model number is the length in inches.
Go to www and find the Morse/Teleflex site. They'll fix you up with the info you have. On my cable, the number was superceded with another number. Seems my cable was prone to fail so they redesigned it. The new cable works great. Then you can come back to iboats and buy it if they have it.
Mark
craigvalk
Thanks Mark, I am good to go, got what i needed.
I appreciate your help sir.
Best
Craig
my problem is got a 1968 omc cable broke.the numbers on it read morse e30?298 204" 3567
dont know what this means but one number is scratched out
and i cant seem to get it off at either end .
i think its called the rack at the wheel
and at the other end there is a ball hinge through the transom
any help would be appreciated
oh and i just read a guys post where he got his but chewed for not providing model number of boat and year so 1968 tom sawyer hue16c omc with a 155hp buick 225 oddfire engine 2bb carb and please dont chew me up like he got it im a newbe
Re: help please dont know anything
