Replacment of motor
pikefisherman
Thinking of replacing motor, but how do I determine to go with a long or short shaft putting on a 15 foot sea nymph tx 150 25 hp max 770 lb max weight. Thinking of going from 1963 10 hp to new 15 hp E tec
smokeonthewater
Measure the height of the transom... Buy that length motor
IE 15" = short shaft..... 20" = long shaft.
MTboatguy
How long is the leg on your current motor? Measure it and then look for something close to that motor. That said, like smoke said 15" short, 20" long
Texasmark
The mid section length mentioned is an average value and there will be some wiggling around those numbers by roughly an inch +/- from vendor to vendor. But a 15 is roughly 15 and a 20 is roughly 20. It's important to have your antiventilation plate (horizontal plate just above the top of the propeller) near even with the bottom of the hull.....like put a straight edge (ruler-yardstick) on the hull and extend it to where the engine lower unit is positioned),with the engine sitting vertical on the transom (rear board that the engine mounts on). So, as the others have said, measure your current engine, if satisfied with it's performance, considering it's hp, and get one about the same length.
