Repower
$980 for manifolds only, $2200 for set with short risers (like stock mercruiser) $2900 for long risers.
A set of new 496 manifolds and risers will set you back about 2100
HT32BSX115
Those are stainless manifolds and risers? I found from Cpperformance: # 520-SM454K For about $2300 but the manifolds are aluminum.
I would want something that couldn't possibly leak. (no blocking gasket needed)
I installed these originally on the 502 and currently list for $1950 and used with silent choice, can find online cheaper. The manifolds are aluminum and do have a gasket but only to ensure no exhaust gas leak (dry joint). Had to replace the tops with 3-inch higher rise ones when motor was repowered.
Also sell these which also are dry joint and list for $1350.
I picked these up for $550
[/URL][/img]
