Repowering Crusader 7.4 XL with Mercruiser 6.1 MAG Stroker Bravo MPI
G. Jay Nelson
I have a 1999 Silverton 392 that has the Crusader 7.4 XL (454 ci) Throttle Body Injection (TBI) engines. The engines are tired, but hull and interior of the boat are in excellent shape, so I have decided to repower the boat. The Crusader 7.4 XL was a 380-horsepower engine, but is obviously no longer manufactured. I have decided to replace these engines with new Mercruiser engines.
There are essentially two Mercruiser options available for repowering my boat: the 350 HP, 6.1 L MAG Stroker Bravo MPI, or the 375 or 425 HP, 8.2 L Horizon DTS ECT in either standard or high output configurations. The 350 HP, 6.1 L Stroker engine is designed as a direct replacement for the 7.4 L GM engine, and economically mates to former 7.4 applications (i.e., engine mounts, transmission/throttle connections, and console configurations, etc.) and can use the current transmissions. The 8.2L engines require the transmissions be replaced, have issues fitting into previous 7.4 L engine spaces, and require extensive console rebuilding to convert to the fly-by-wire system.
In short, the 350 HP, 6.1 L Stroker engine is a much more cost-effective conversation than moving up to the 8.2 L engines. My concern is the boat’s performance with the lower HP engines. The low-end torque is greater on the 350 HP, 6.1 L Stroker than the old 7.4 L Crusader and the top end RPM is higher, but the HP is 30 HP less (combined 60 HP less). The Silverton 392 is 39.9 LWL and has a maximum weight of about 28,000 pounds. I typically cruise at 8.5 knots (displacement speed), but would like the occasional speed to outrun weather. Has anyone repowered a 39-foot cabin cruiser with the 350 HP, 6.1 L MAG Stroker Bravo engines that can offer me some insight as to the potential changes in performance?
Welcome to iBoats . . .
I have not heard of the 6.1L do you mean the 6.3L ? I happen to have a pair of 6.2L engines, which I'll send you a PM about.
Are they outdrives or full inboard?
Your options (IMO) are to
get re-built 7.4's or go with the 8.1/8.2 . . . The 6.3's may be OK.
I run the 6.2L 350 HP engines and they do pretty well, but my boat is less than 1/2 the weight of your boat.
If you are in salt water, then avoid anything that does not have FULL closed cooling, so the 8 liter engines are out, if that be the case.
The 6 liter engines will probably be OK, but you will probably need to get lower pitch props to get the best performance.
that silverton is HEAVY and should have had diesels from the onset. you need torque that a big block brings. While I would love to suggest swapping to a 6.2 liter with all the mercruiser hype...... google how unhappy everyone is that has gone that route
I would really recommend either rebuild your 7.4's (you can easily get 450hp from them), go with a pair of 8.2's or go with stroker 540's (8.9 liter) and stick with Big Blocks. they will literally bolt in place of the current 7.4's you have. since externally the 8.2 and the 7.4 are identical, I do not understand your comment.
dont think HP, HP is a number that is derived from the Torque the motor makes. HP= Torque x RPM / 5250. Torque is what turns the prop and pushes the boat. Torque is what gets you out of the hole. the magic HP number is only how fast you can go well after you get out of the hole and are flying along.
big boats need torque. the 6.2 makes up HP for lack of displacement (and torque) by spinning it faster on the top end. the 6.2 is a 4" bore and a 3-3/4" stroke. your current 545 / 7.4 is 4.25" bore and 4" stroke. rebuild them and you have 468 cubes, swap the crank to a 4.25" stroke and you have 496 cubes or 8.1 liters from your current block. the 502 is a 4.468" bore and a 4" stroke. (the Gen VII 8.1 is a 4.250" bore and a 4.375" stroke)
you do not need to go DTS, you only need to swap the long-block unless for some reason you want DTS
I would recommend you talk to your local machine shop and rebuild what you have or look at a pair of https://michiganmotorz.com/8-2l-502ci-base-marine-engine-425-hp/ at a minimum, then swap over your exhaust, accessories, etc.
if this is the motor you are considering
the prop curve is about 100 ft-lb of torque down from the crusaders you have.
