Restoration boo boo
J. Mark
The drain for my bilge is right under the front of the engine. When rebuilding the stringers I spilled some epoxy which found the low spot and filled the threads. Should be easy to clean out . . . well until I installed the engine
ARGHHHHHH!!!!
Boss Hawg
Re: Restoration boo boo
ARGHHHHHH!!!!
Heres your sign :p
boat1010
I would think that you can just use a tap and cut the threads again and remove the epoxy.
J. Mark
If I could find a 1" pip[e thread tap I would do that-so far no luck. Looks like a wire brush, a small chisel and some elbow grease might be my best bet. If it wasn't against glass, a torch would work, but I'll save that option for when I totally give up on the project!
The_Kid
I don't know if it would work or not, but since your just cutting epoxy could you make your own tap out of a piece 1" pipe. Cut four notches out of the threads. It might create enough of a cutting edge to remove the epoxy.
C-worthy
That's a great idea! You don't need a hardened steel pipe tap to cut threads in the epoxy.
Tim Frank
Here is source for the tap :
http://www.victornet.com/cgi-bin/vi...ps+and+Dies:799,623,1674, 801,798,800,803,613
Make certain of the thread series, though. Are you sure that it is a 1"-11-1/2 NPT thread? That's a good size hole....
How did you measure?
3/4-14NPT is almost identical thread to 1"-14 UNS.
You will need to drill a through hole first.
How are you able to access the hole?
Tap drill for 1" NPT is 1-5/32". the 3/4 NPT is 59/64" , the 1" UNS is 15/16"
Just FYI if it is a standard screw in plug the diameter is 3/4" pipe thread.....
J. Mark
It is 3/4- you are correct. It looks bigger. I was going to notch my spare plug, but they are expensive
http://www.go2marine.com/product.do?no=86050F
I have some scrap 3/4 pipe with good threads so making my own thread cleaning tap should be easy enough.
Glad I posted this, you folks just saved me some time.
