Restoring a 1966 Johnson 6hp Seahorse
emsfire138
I am restoring a 1966 Seahorse 6hp. It has a plastic 2-blade prop on it now. I'd like to replace it with an aluminum prop. Should I try to find a 3-blade?? What pitch would be best for this size motor? Also, has anyone found any good place to get replacement hood decals?<br />**Curious...what is the difference between the newer 6hp and 8 hp Johnsons? All specs (bore/stroke/displacement, etc.) are the same. Is the only difference in the carbs? (Same for 9.9s and 15s, I guess). Just wondering.....
Paul Moir
Re: Restoring a 1966 Johnson 6hp Seahorse
The engine originally came with a 8 x 7 1/4, 2 bladed aluminum prop. Apparently, no other props were offered.<br /> Picture.<br />Information.<br />From the Old OMC Site. <br /><br />Sorry, I don't know the difference between the 8 and 6. I expect you'll find exhaust tuning and rpms contribute though. Mabey even the ignition (spark advance).<br />Good luck with the restoration!
rolmops
Hello.<br />For propellers:<br />boat length:14' to 16' 7 1/4x6 1/2 Light Load Michigan 012068<br /> 14'to 16'All Loads 8 1/4x8 omc 387334 or Mi.012008<br />14 to 16 runabout 8 1/4x9 omc 39534,Mi 012101<br />12 to 14 light load 8x7 1/4 omc 376988,Mi. 012005<br />12 to 14 light load 8 1/4x 8 1/2 omc 377635,Mi.012007.<br />Sorry, I can't find the decal website right now,probably steel spike or chinewalker can fill you in.
emsfire138
Thanks for the info...I was able to locate the decals. This motor will primarily be used on a 12ft. fishing boat (very light). I found a 3-blade 81/4 X 81/2 prop on this site. This should work out pretty good for this combo, I would assume. Another quick question, though. I have another Johnson O/B (mid 80's 15hp.). The gas tank for this motor was stored for quite a while, and has alot of moisture and corrosion inside. Is there anything that I can use to clean it out? It doesn't even want to prime up when I pump the bulb - probably junk in the pick-up. Any suggestions?
rolmops
Hello.<br />Empty the old gas out and if you can take the pickup out and clean thoroughly.Take a handful of roofing nails and dump 'em in the tank add maybe a pint of fresh gas. Close the tank and then, shake the living daylights out of it.Repeat this a few times.This should help you get rid of loose corroded pieces.<br />Clean and rinse with gas and then reinstall your pickup.<br />Good luck.
emsfire138
Thanks for the suggestion...I'll give that a shot.
Solittle
The 1966 6 hp is a good motor. I had one on a 17' square stern canoe and it was to much power,
