Retaining ring on1975? Johnson
sinkhole
Can anyone tell me which way is up on armature retaining ring (bevel side up or down ) also what is the milled out section for? Thank you in advance.
Nordin
Please tell us what engine you are dealing with model number and HP.
Hard to answer if we do not know engine model and HP.
sinkhole
No info. available OMC stoped making in 1973 i think. Made in Peterborough Canada same basically as 25 hp.
If you are referring to a 20hp, it is basically the same as an 18hp. It was made well into the Late 70s.
