Rinsing small motors
Joey One
Why doesn't anybody make a fitting to permit rinsing of small OMC motors without pissers? I now use a deep bucket, ropes and boat hook when the motor is on my sailboat. But this is very tiring. I would sure like to learn of an easier way.
crazy charlie
Re: Rinsing small motors
Have you ever tried a set of earmuffs???? It is designed for that very purpose.Charlie
Joey One
Earmuffs don't work because later model OMC's have the water intake at the rear of the gearcase instead of the sides. Thanks anyway.
ehenry
What horse power and model motor do you have?
crazy charlie
Is there any way to cut the end of a garden hose and push it in there??Charlie
RobG
What I've been using for my old Johnsons is a 55 gal blue plastic drum with the top cut off. Just back your boat up to the barrel and lower the motor in and rinse away! That way you don't soak your whole yard with water. The earmuffs definitely don't work well with those motors.
Joey One
1992, Johnson 4 HP Deluxe. It's on a 23' Ranger<br />sailboat allways in the bay.
Joey One
Somewhere, in these archives, somone mentioned a Temco device number for rinsing these small OMC's.<br />I'd like to find this number and maybe advertise for it. <br />It's necessary to lean over the transom to to attach<br />something.
