Risers and Manifolds interchange?
Superwhitey
I need a new set of Risers and Manifolds. They are on a 2000 Larson 206SEI. Most of them I have been looking at on Ebay look the same, and I was wondering if any of them would fit if I got the matched set.
My Riser # 3857402
Manifold 3857579
Personally, I only use OEM manifolds. They end up lasting longer and you aren't saving much by going after market.
Superwhitey
There are so many OEM Volvo part numbers, that look the same. Mine seems to be a little harder to find. Kinda oddball.
Ayuh,.... Welcome Aboard,...... You haven't said what motor ya got,....
Superwhitey
It's a 5.0 volvo. GM.
Volvo discontinued the risers. There are many model numbers, wondering what the differences are. Mine has the exhaust port, I guess to heat air for the carb. Don't think I need that.
What is your model number?
for an "EF" model:
riser 3857944
manifold 3857723
they are both available
Superwhitey
I think it is or was a 5.0 GL, I put in a 5.7 shortblock, and didn't keep the tag off the engine. It is a carb engine, if you meant EF being Fuel Injected.
