ROCKY MOUNTAIN ENGINES
kopy kat
Has any one dealt with these folks? I was told that they have been rebuilding marine motors for 30+ years. Claim to have less than 3% return rate on their rebuilds (that's good, isn't it?).<br /><br />I've got one on order, just wanted to check them out more.<br /><br />Also, can you tell a GM 305 from a 350 by outward appearences??<br /><br />thanks, Larry :eek:
crazy charlie
Re: ROCKY MOUNTAIN ENGINES
I have never heard of them.Usually you do the checking out of a company BEFORE you place an order??!!Very tough to tell the difference between the 2 blocks,nothing obvious.Wish you all the best with the rebuild.Im sure someone here has heard of them.there are many quality wrenches here.Charlie
There's Nothing Wrong with using a local machineshop.......<br /><br />There are Casting #s at the left-rear on the Block, just behind the Head......<br />With these #s you can find out What,+ When the engine was built For, at the beginning of it's life(which has little to do with it's Present incarnation)........<br />Look Here;<br /> http://www.mortec.com/ <br /><br />Good Luck.......
