Round Peg Into Square Hole . . . Vintage Destroyer Style Helm Wheel Install
LoweSuperior
For those so inclined . . . mounted my vintage 70's square shaft helm wheel to my brand new Uflex Rotary Planetary Steering System today. The pics will tell the tale but basically potting the square void with lead free solder. Not rocket science but it seems to work. Why bother? . . . you may ask . . . because my helm kit didn't come with a wheel and I had it on hand.
Click image for larger version  Name:	3.jpg Views:	4 Size:	42.0 KB ID:	10812423Click image for larger version  Name:	4.jpg Views:	1 Size:	57.5 KB ID:	10812424Click image for larger version  Name:	6.jpg Views:	1 Size:	85.3 KB ID:	10812426Click image for larger version  Name:	7.jpg Views:	1 Size:	70.3 KB ID:	10812427Click image for larger version  Name:	13.jpg Views:	1 Size:	45.0 KB ID:	10812431Click image for larger version  Name:	15.jpg Views:	1 Size:	70.2 KB ID:	10812432Click image for larger version  Name:	16.jpg Views:	1 Size:	57.8 KB ID:	10812433 17.jpg
Nice work cosmetically...but will it hold? Solder is pretty soft. If it breaks try Marine Tex, although I am not sure that is a lot stronger.
If that fails, cut a piece of heavy steel into a square and drill it for the steering shaft. File a new keyway. Alternatively, a large steel square nut (farm equipment?) might also fit the square
