clearbluewater
- Joined
- Aug 19, 2019
- Messages
- 45
I was hearing squeeking sounds from engine, after changing belt sounds are gone, took it for test drive, it seems to be running ok. New belt is 10mm (1cm) shorter than old one. This was because of feedback from other owners.
The rpm gauge seems to misreporting, showing 5k, 6k when its not. Engine sounds fine. As I kept driving the rpm would get close to normalizing but not fully.
After 2 hours I noticed rpm starting to show accurate reading, based on throttle, engine sounds. But not sure if it's fixed.
Before I go out again I wanted to check if this is normal as it is a new belt? Any adjustments needed?
