Rub railing. 😕
titaniumneck
Does anyone know where I can order boat rub railing by the foot. Only missing about 4 foot, but cannot find any by the foot, only by the roll, expensive. Any help.
Yegboats
I can possibly help. Do you have the pictures/measurements? Also make model and year of boat.
titaniumneck
No Title
I believe 1988 sprint, pretty much like this one, except aluminum with black rubber insert about an inch and a quarter.
Watermann
You have to know the exact profile that your rubrail uses, a miss is as good as a mile when it comes to the rubrail insert. I buy mine from Wefco by the foot.
You have to call them to place an order no shopping cart. Their inserts are rubber too not vinyl.
http://www.wefcorubber.com/PDF/marine/Rub-Rail Inserts.pdf
That prifile looks like some of the inserts that Taco Marine sells.
Watermann
Oh you need both, so what happened to yours? Any pics of what was on it, the shape of the boat dictates what RR configuration you can get on there.
titaniumneck
It was like that when I bought it, it's a rebuild in progress. Transom was good and floor. So polished it up, recarpet, repower( off my old Jon boat. Trolling motor. Rub rail across front, I'll get pictures sooner or later, busy as heck.
titaniumneck
No Title
These are the pictures of what I need.
jbcurt00
titaniumneck
Top right corner of any iboats page
Click Messages
There should be a red square square between the word messages and you're user name. If you havent opened the 'new' messages, there shoiuld be a number inside the red square. Tells you how many new messages you have.
Once the messages page opens, new messages should be the top half of the page in an Inbox Preview. Short messages may be fully displayed.
Find the message you want to read, and below the senders name, click the subject title.
That will open the message and it will be deleted from the message count inside the red box I mentioned above.
Once you read, send or reply to a message, the message can be found again at the bottom half of the messages main page in the messages folders:
Inbox
Sent
Trash
There is a maximum number of messges you can keep, if you delete a message it goes to the trash can, and you must then empty the trash to fully delete it and remove.it from your message count.
