runaway
Alumarine
Re: runaway
Revving at 9,000 rpm and unable to stop it are a couple of signs.
Silvertip
Re: runaway
Put a brick on the gas pedal of your car. Start the engine, leave the tranny in neutral. That's what runaway sounds like. Pieces going through the side of the engine is another sign that the engine perhaps ran away. Pulling the throttle on your outboard back to idle and having the engine continue to spin itself nuts is another indication.
1nebel0
Re: runaway
How about having the carbs off and squirting gas in the manifold...That should help silence the motor......
