Running in the engine
mark_fitzy
Well finally getting a new motor installed, whats the correct process to running in the motor and can I ski and tube while running in the motor?
Re: Running in the engine
Ayuh,... What motor We talkin' about,..?? Vintage,..??
Fishermark
While it may be good to get some ideas here - since you are getting it installed, it would be best to ask the person or company doing the installing. That way, if there is an issue, you can say you did as instructed.
