Running my 302 5.0L Cobra on a test stand - my video journal.
SpitAndDirt
I thought those of you looking to test your own motor out would find these helpful. Especially those of you who are experiencing fuel pump problem
Mentioned the firing order was incorrect according to the sticker on the engine. A V8 firing order is 1-8-4-3-6-5-7-2, what did the sticker have on it?
SpitAndDirt
I goofed in the video and read the firing order incorrectly from the sticker, but did state the firing order I'm using correctly. 1-3-7-2-6-5-4-8
I would stick with plugs to drain your block. That way you can poke inside the block with a wire to loosen up the rust that will build up.
SpitAndDirt
Yeah, my bet it isn't.
Correct, nothing about the starter said that it was a marine starter. And before everyone starts a flame war about why I shouldn't have a non-marine starter on my boat, let me present a few pictures of the original starter. From what I can tell, only sealant was added to the solenoid / electrical contact area to keep fumes from permeating into the case and possibly causing an explosion. As for the new starter, I fully disassembled it to inspect for seals, gaskets, and other forms of spark / explosion prevention. Besides two moisture drains, the new starter is completely sealed. Probably even better because it doesn't have any gap around the bendix area.
To address why I didn't run the block drains straight out, I haven't made up my mind yet as to whether I want to keep them as right angles or not. It would be easy enough to remove the right angle brass fittings to poke through any rust blockage should the need arise.
bajaunderground
I have the Volvo-Penta/OMC version (1996) of the 5.0L H.O. and your corrected timing is the same as mine (1-3-7-2-6-5-4-8)? That looks to be the sticker for the 460c.i. as it's the only reference I could find in my service manual with that particular firing order?
