Running on 5 out of 6 cylinders? 90 hp inline 6
Imjus4u2nv
I had a problem recently with my engine which caused my #3 cylinder to overheat (causing melted aluminum on inside of cylinder and on the sparkplug). I am not getting spark to that cylinder and while I am troubleshooting the cause of overheating (maybe running to lean? Bad water pump?) I am looking for opinions on running on 5 of the 6 cylinders.
It runs great on 5 cylinders, but was wondering if anyone has done this before on an inline 6 and if they engine held up or blew up. I want to use the boat a few times until I can troubleshoot the #3 cylinder but don't want to make it worse.
Thanks in advance for any input.
Jared
Re: Running on 5 out of 6 cylinders? 90 hp inline 6
Bad business........ if that piston has weakened and any piece breaks apart your block is going to be trashed and maybe the crank too.
I would not advise it. Sounds like a carb let it lean out and burn.
