Running wire from the wake tower thru the hull into the boat
jcole59946
Howdy,
I need to run 12 gauge duplex wire from my wake tower through the hull and into the boat.
What type of sleeving should be used?
Is there a fitting that should be installed in the hole thru the hull?
Is it possible to set up a water proof quick release connector between the tower and the hull?
Thanks a bunch!
Plastic sleaving . . . the automotive kind is fine
You could use a rubber grommet at the hull or just use silicone adhesive to prevent any water from getting in.
You could add a connector and use electrical grease to get a water resistant connection, in case you ever want to remove the wake tower.
