Rust Bullet?
Re: Rust Bullet?
But you have an aluminum hull :confused: unless you are going to use it on the trailer............
Mojo^
Re: Rust Bullet?
It's supposed to work on aluminum as well. I sent them an email tonight for clarification. This should prove interesting.
Re: Rust Bullet?
Aluminum does not "rust" but it suffer's from oxidation on the surface and if mixed with the wrong metals (and/or chemicals) it will suffer galvanic corrosion.
