sacrificial anodes
BAYDOG225
What would happen if I don't have one? On my 1986 30hp, the owner before removed the anode to install a hydofoil fin.
In fresh water nothing may happen.----------You need to provide information as to the water you play in.----Do you leave the boat in the water all year round.------Do you know how an anode works ??
tramsdell
Banned
If i may piggyback, if one went from a saltwater use to freshwater only and the anode is all crusty... should it be replaced or removed?
BAYDOG225
Fresh water only, and trailered after every use. Yes I know how they work.
F_R
Anodes don't do anything when the boat is on a trailer. And outboards went about 80 years without anodes. OK so they corroded in salt water. I'm not convinced the anodes stopped that. I can't forget when Mercury first put sacrificial trim tabs on their motors. And Mercs were as bad or worse to work on than any of the others. To me they are a for whatever-they-are-worth thing.
Vic.S
Very little point in having an anode then. If its on a trailer an anode is not needed and in fresh water to be effective you would need a magnesium anode anyway. Zinc becomes passivated with an oxide coating in fresh water.
(Magnesium is too reactive to use in salt water)
You need a magnesium anode in freshwater.
The rules regarding anode type are that zinc is only effective in saltwater ( they are made of special high purity zinc which conforms to a US military specification)
Aluminum anodes are suitable for salt water or brackish water. They are made of a special alloy containing among other alloying elements a small percentage of indium.
Magnesium anodes are suitable for fresh water use only. They are made of magnesium containing small percentages of aluminum and zinc
