SAE or metric
Donzi GT250
Re: SAE or metric
Ayuh,.... I believe you'll find it's 3/8"- 16.... Donno the length...
measure it...
Thanks for the reply.
If I had the bolt to measure I wouldn't have had to make this post.
Re: SAE or metric
Pretty easy to measure the depth of the hole.
Re: SAE or metric
Sorry, I thought you did!
I promise I will never give you an attitude again...of course I will never try to help you again either.
Re: SAE or metric
Ayuh,... Ditto that....
Lou C
Re: SAE or metric
All the fittings on the older OMCs are SAE, no metric...
keep in mind you are asking a question about a old boat, that not too many people still work on, I fiddled with mine last spring, to get more clearance for the raw water intake hose, it's in a really tough spot to get at, small size can't recall what it was....
you have to be REASONABLE about what you expect to get answers for on this forum....
cr2k
Re: SAE or metric
So take 2 or 3 diff sizes out with you.
gus-gus
Re: SAE or metric
Maybe he left since none of the information offered was good enough for him, I wish him luck elsewhere. Jeesh!
