Salt...Are there any more uses that you can think of ?
Vlad D Impeller
60 uses of SALT...can you believe it??
By Ms. Jerry McGinnis.
1. If you drop a whole egg on the floor, pour salt all over the egg, let it sit for awhile, then use dustpan, the egg will come right up, without all that mess.
2. Soak stained hankies in salt water before washing.
3. Sprinkle salt on your shelves to keep ants away.
4. Soak fish in salt water before scaling; the scales will come off easier.
5. Put a few grains of rice in your saltshaker for easier pouring.
6. Add salt to green salads to prevent wilting.
7. Test the freshness of eggs in a cup of salt water; fresh eggs sink;bad ones float.
8. Add a little salt to your boiling water when cooking eggs; a cracked egg will stay in its shell this way.
9. A tiny pinch of salt with egg whites makes them beat up fluffier.
10. Soak wrinkled apples in a mildly salted water solution to perk them up.
11. Rub salt on your pancake griddle and your flapjacks won't stick.
12. Soak toothbrushes in salt water before you first use them; they will last longer.
13. Use salt to clean your discoloured coffee pot.
14. Mix salt with turpentine to whiten your bathtub and toilet bowl.
15. Soak your nuts in brine overnight and they will crack out of their shells whole. Just tap the end of the shell with a hammer to break it open easily.
16. Boil clothes pins in salt water before using them and they will last longer.
17. Clean brass, copper and pewter with paste made of salt and vinegar, thickened with flour
18. Add a little salt to the water, your cut flowers will stand in for a longer life.
19. Pour a mound of salt on an ink spot on your carpet; let the salt soak up the stain.
20. Clean your iron by rubbing some salt on the damp cloth on the ironing surface.
21. Adding a little salt to the water when cooking foods in a double boiler will make the food cook faster.
22. Use a mixture of salt and lemon juice to clean piano keys.
23. To fill plaster holes in your walls, use equal parts of salt and starch, with just enough water to make stiff putty.
24. Rinse a sore eye with a little salt water.
25. Mildly salted water makes an effective mouthwash. Use it hot for a sore throat gargle.
26. Dry salt sprinkled on your toothbrush makes a good tooth polisher.
27. Use salt for killing weeds in your lawn.
28. Eliminate excess suds with a sprinkle of salt.
29. A dash of salt in warm milk makes a more relaxing beverage.
30. Before using new glasses, soak them in warm salty water for a while.
31. A dash of salt enhances the taste of tea.
32. Salt improves the taste of cooking apples.
33. Soak your clothesline in salt water to prevent your clothes from freezing to the line; likewise, use salt in your final rinse to prevent the clothes from freezing.
34. Rub any wicker furniture you may have with salt water to prevent yellowing.
35. Freshen sponges by soaking them in salt water.
36. Add raw potatoes to stews and soups that are too salty.
37. Soak enamel pans in salt water overnight and boil salt water in them next day to remove burned-on stains.
38. Clean your greens in salt water for easier removal of dirt.
39. Gelatin sets more quickly when a dash of salt is added.
40. Fruits put in mildly salted water after peeling will not discolour.
41. Fabric colours hold fast in salty water wash.
42. Milk stays fresh longer when a little salt is added.
43. Use equal parts of salt and soda for brushing your teeth.
44. Sprinkle salt in your oven before scrubbing clean.
45. Soaked discoloured glass in a salt and vinegar solution to remove stains.
46. Clean greasy pans with a paper towel and salt.
47. Salty water boils faster when cooking eggs.
48. Add a pinch of salt to whipping cream to make it whip more quickly.
49. Sprinkle salt in milk-scorched pans to remove odour.
50. A dash of salt improves the taste of coffee.
51. Boil mismatched hose in salty water and they will come out matched.
52. Salt and soda will sweeten the odour of your refrigerator.
53. Cover wine-stained fabric with salt; rinse in cool water later..
54. Remove offensive odours from stove with salt and cinnamon.
55. A pinch of salt improves the flavour of cocoa.
56. To remove grease stains in clothing, mix one part salt to four parts alcohol.
57. Salt and lemon juice removes mildew.
58. Sprinkle salt between sidewalk bricks where you don't want grass growing.
59. Polish your old kerosene lamp with salt for a brighter look. Remove odors from sink drainpipes with a strong, hot solution of salt water.
60. If a pie bubbles over in your oven, put a handful of salt on top of the spilled juice. The mess won't smell and will bake into a dry, light crust which will wipe off easily when the oven has cooled.
Perhaps you may have a few of your own uses to add.
Shizzy
Ensign
Re: Salt...Are there any more uses that you can think of ?
#15 is interesting.........
JB
Prisms and lenses of pure sodium chloride crystal are used in optical instruments because NaCl passes wavelengths that plain glass blocks.
dolluper
Add salt to a car body so it will rust faster
mike64
Salt applied liberally to french fries makes them really tasty.
Interesting!
I always found it fascinating that two separate elements, sodium and chlorine, which by themselves are deadly poison, combine to make plain old table salt, which not only makes food taste better but is necessary for survival (in moderation). Chemistry is cool.
idrownworms
licking salt before a shot of mezcal wasn't listed
I've even seen old men put a shake or two of salt in beer
fishrdan
uses of SALT,,, By Ms. Jerry McGinnis.
Little Johhny McGinnis comes in crying about his scraped up/bloody knee...
#61 Salt is a good disinfectant, rub ample amounts into the open wound :D
jam1ej20
#62. Salt sprinkled liberally is an effective slug-icide.
xxturbowesxx
I think no 5 is inaccurate..I think that the rice in the saltshaker is to absorb moisture not make it easier to get out of the shaker..
mike64
The rice comes out of the shaker easier because the rice absorbed the moisture that would cause it to stick together.
First time I took a trip to Florida, I thought "what's with the rice in all the salt shakers??":confused:
i386
A little salt on your coaster at the restaurant/bar will keep your cold beverage from sticking to it.
You can catch a bird if you sprinkle salt on its tail.;)
jlinder
When your tongue is burning from really spicy hot food put some salt on your tongue to stop the pain
flargin
Actually, they area all have the same level of moisture, but it is makes a good agitator. You can use popcorn kernels... Thanks Alton Brown!
Knot Waiting
Lay several hundred miles of it on the desert floor and let people race cars on it.... Call it Bonneville or something nice.
crazy charlie
shake some salt in your eyes if you want them to really burn.
salty87
salt is great for purging crawfish.
i prefer to let slugs drown a happy drunk death, hard to spare the beer though.
