salt water question
proshine43
Hello everyone. I have a 4.3 cobra. I live right by the ocean. I plan on using it in fresh water as much as possible, but the harbors launch ramp is only 5 minutes away. Is there any big issues with running in salt water and flushing it out afterwards. Thanks.
Re: salt water question
Ayuh,... Just the usually Rustin' away ya get playin' in Saltwater....
proshine43
Thats a bummer. So flushing it out completely just after usr wont help? What do other ocean boats with i/o have that they can go out in.thanks for your help.
HT32BSX115
Exactly what he meant.
I/O's have some cast iron parts that corrode faster than other parts. (like engine blocks, manifolds and risers)
They begin to rust immediately. Not much you can do about it. You can reduce it but not stop it unless you install closed cooling. (except the risers)
All that stuff rusts in "fresh" (non-salt) water lakes too........just not as fast as it does in salt.
Any boat that used in salt water will experience "rust" or corrosion. It's a fact of life.
Flushing will of course help but not eliminate it altogether.
Lou C
My boat sits on a salt water mooring 6 months out of the year, and it's been used in salt water at least half of its life, and I replaced the manifolds once and the thermo housing once, and the themostats themselves about every other year. If you are flushing it after use I would not worry. The corrosion issue with salt water is a real issue but it takes years for it to reach a point where you will have trouble because of salt water use. A 1990 Cobra 4.3 will have the one piece manifolds, that are no longer available, I suggest you check em after 5 years of salt water use. If they are getting really corroded, then you can replace them with an aftermarket kit that converts it to a conventional two piece design, but my experience has been that the one piece units last long even in salt. I fill my engine and manifolds with the best -100 antifreeze when winterizing and that seems to keep the inside of the engine from rusting much. I looked in the intake manifold and the water passages in the block when I replaced the water pump and thermo last year and there is no flaking rust in either place.
Oh and salt water is not all bad, keep in mind freshwater rots wood (transoms, decks etc) but the fungus that rots wood can't live well in salt water so you don't see as many rotted transoms on salt water boats....
full stringer
using salt away greatly reduces corrosion much better than just fresh water. it makes a coating inside the manifolds and risers to resist salt intrusions into the cast iron pores. a good run to the lake once in a while is a good idea as well much better than a hose muff
proshine43
Thanks for your advice. I promised my family a cruise around the harbor at christmas time and my son wants to do a little fishing outside the harbor. I'll look for that salt away. Thanks again
