same motor
martin47
hi i have a 115hp mercury....(1986) there is a 90hp mercury ( same age ) for sale with a idle problem....... my question is are the parts the same. thinking of buying for spear parts . mine is a straight 6 and the 90hp is a straight 4 ??? :confused:
Laddies
Banned
Re: same motor
They should both be I/line 6s the parts are basically interchangeable but the 90HP has different port timing than the 115
Willyclay
Re: same motor
The only way to know which parts are the same is to go to the Mercury website and check the part numbers for both motors. Good luck!
Re: same motor
Martin, Usually the 80 HP motors are inline 4 cylinder motors. Although some parts are common, obviously there are significant differences
