Schematic / tube connection through hull
Prop Buster
I found that one of the bilge pump tubes is disconnected right behind the hull. I need to know how the "cap" that is outside of the hull is connected to the tube. Does is screw off or does it snap in place ? Port is located on the stern of the boat, thankfully just above the water line and water comes right in. Need to connect the port back onto the actual tube but don't know if it screws on snaps on , . Any ideas? Thanks in advance
cr2k
Re: Schematic / tube connection through hull
Usually the hose is held on to the barbed fitting with a hose clamp.
Hose clamp holds the hose on the "barbs". If the fitting is plastic, more than likely the fitting has broken and the entire assembly needs to be replaced.
