Schoenfeld Headers
YmeHP
Does anyone have a recommendation on marine headers? I plan on replacing my stock manifolds on my sbc while i'm in the process of swapping motors. I'm installing a remanufactured rapid-o marine longblock with an Edelbrock intake and either an Edelbrock or Holley carb. Comments or concerns?
Re: Schoenfeld Headers
Got a link to what you are looking at?
Those are over the transom, Dry pipes........
They'll be So LOUD that you won't be making many Friends on your home waters..........
If you plan on Hot Rodding the boat,..... The Exhaust is the 1st obstacle to over come,....
But,.... I'd go with Low, Wet pipes........
YmeHP
Thank you, who makes a good set of manifolds to replace the stockers? I really don't want to spend $1,000 plus on headers!
Coors
1 3/4 inch are for high rpm, which boat engines don't run at.
I bought my boat with thru-hulls, the water in them deadens the sound pretty good.
The previous owner probably did it for $400.
