Screw on Side of Lower Unit - Purpose?
fmjnax
This should be simple. In this image, what is the purpose of the screw circled in red? It's listed as a bearing setscrew but I can't tell what its full purpose is. Part number 324852 for a J90TLCUR, if that helps any.
You can take that screw out and put it back in all day long.----Nothing will happen inside when screw is out.
Faztbullet
Usually when a customer tells me this it usually ends up leaking..make me $$$$
