Sealed Oil Trailer Bearings and surge brakes
Inside Trader
Just bought a Double Eagle 185 with a single axle trailer. Bearings appear sealed with an oil float in them. Is there any maintenance I can do here. What do I need to know?
Also any advice on surge brakes? Routine maintenance?
I'm totally new to boating, other than a car topper 12 ft aluminum with a 9.9.
Re: Sealed Oil Trailer Bearings and surge brakes
The first thing I would do is replace them. It's not if they will leak, it's when they leak.
Thalasso
You don't need to replace them to put something else on that will fail at some point. I had them on a previous trailer and they are great.
Do they have a clear end cap where you can see the oil. That would be the only fail point. They use 90 weight oil ( rear end grease/oil )
Tractor trailers use that same type of setup. You don't hear of them loosing wheel brg's.
cribber
My EZ-Loader came with the same setup. Note the oil level and make sure it always stays there. Keep an eye on the cap and replace them when they start to crack from sun exposure. I've had mine for four years and so far so good... all bearings fail from a lack of maintenance no matter what the type.
PKomrowski
Those are fine, just watch them. They like everything elce in life will wear out. Proably what will happen is the inner seal will go bad and let water in, then you will have to redue them. I would keep them though as they are just as easy to work with as the others.
