sealing hole in transom
MrX-175
I just got a new Glastron and I want to install my fishfinder. I read a bunch of the transducer installation threads so I think I have that figured out.
My question is what's a good looking way to seal the hole in the transom that the cables go through? Is there some sort of cap or cover you can put over it?
Texasmark
Re: sealing hole in transom
Might pose that question to your local marine dealer, who, knowing what it takes to fix it, might just stock what you need.......a cap, maybe not.....sealer, surely.
Mark
Silvertip
Run the transducer cable up through the splash well drain hole. No cap or sealer needed.
Or, if you must drill a hole for cable entrance, here is one style of cover. There are also chrome plated metal versions that are a little more attractive. Either way, they require two more holes for the mounting screws.
