Securing Outdrive on my I/O
jimbo1229
So ive been using straps around my motor lifting actuators and I was wondering if this is ok and if not do they make something to lock the outdrive of the I/o in place while trailering?
Silverbullet555
Re: Securing Outdrive on my I/O
Why do you feel the need to lock it in place? And, by in place do you mean so it can't swing left to right or moving up or down?
Mason78
You shouldn't have to "lock it in place".
oldjeep
It should be fine all on tis own. If it is dropping while driving, then fix the leak.
JimS123
Yes, they make a trailering bracket for I/Os. You can buy one here on IBoats. Only a coupleabucks! Its a simple plastic sleeve that goes over the cylinders.
Mercruiser actually recommends the use of one in their Owner's Manual.
jimbo1229
silverbullet it isn't leaking its more preventing it from swinging back and forth going down the highway. I cant imagine over time that's good for anyhthing
NYBo
Secure the steering wheel with a bungee cord or ratchet strap.
I usually tie the outdrive (s) up with a line to the ski tow hook or something. Probably not needed, just peace of mind.
oldjeep
Swinging? That seems odd. Not going to hurt it but I can't say that I've ever noticed an I/O swinging back and forth on a boat.
smokeonthewater
it won't swing in normal driving and if it did it wouldn't hurt anything in your, your kid's or your grand kid's lifetimes.
Silverbullet555
Thanks. I wanted to make sure we were all talking the same thing.
As others have said, I can't imagine it swinging around. Mine will often work to one side but it stays there once it is there. You could bungee cord the steering wheel I guess or use a strap to try to keep it straight, but I wouldn't worry about it.
jimbo1229
ive been using a strap so ill keep using it, thanx guys just figured id ask.
