SEI replacement drive for merc
bjf1280
Does anyone know anything about the SEI replacement outdrives for mercruiser out of Clearwater FL.?
Haut Medoc
Re: SEI replacement drive for merc
I have not used one personally, but there are members that have......
The consensus is that they are OK.....
I'm sure some who actually own them will ad their insight.......:)
bjf1280
Fishermark
I have one on my boat and have had it for a couple years now. It works great - the only quality issue seems to be the finish. It corrodes fairly easily. Whatever paint they use doesn't stay on too well, but mechanically I've had no issues.
bjf1280
Thanks for the quick reply, I'll keep looking at the posts
TyeeMan
Howdy,
I have a one year old SEI drive on my boat. So far mechanically it's great, my only complaint is that it has a promenent gear whine at idle speed. I contacted SEI and they said that it was normal. Might also be that I have an aluminum boat, perhaps it resonates sound more than glass.
I agree with Fishmark, the finnish could be a little more robust as far as it's adhesion to the aluminum. Just keep it waxed and don't ding it, you'll be just fine :). I would purchase another if I had to, , , knock on wood.
DHPMARINE
I wasn't happy when I put one on a customers boat a u-joint let go.They repaired the drive,but we had $1600.00 damage on the boat.This happened in the first 5 hours after installation.
DHP
180shabah
I have an SEI lower on my boat, I have only had it for one season but no complaints so far. My boat is trailered, so I don't expect to have any issues with corrosion as was mentioned above.
