Serial Number
scrmnegl
I have a Mercruiser in my boat and I don't know if it was originally there when the boat was manufactured. Is there a way to dig through any records to finds out the history of the motor or is there no records kept for a motor?
Thanks!
Re: Serial Number
Ayuh,... If you post the #s found,...
Don, or another Tech who's still "In the Biz" can usually find something for ya,....
Not that it really Matters,... Hulls are Repowered/ Refitted everyday...
Good, Bad, or otherwise,.. You've got whatcha Got....
Fun Times
Re: Serial Number
Thanks!
Post all the mercruiser serial numbers you can find, And we will do are best to help you out.:)
Re: Serial Number
It's a 1987 model 165. With is a 3.7L engine. aka 470. what year is your boat?
You can also find the OEM service manuals up in the adults only sticky at the top of this forum. You need #8 for your engine, #6 for your outdrive.
gettin'even
Re: Serial Number
Thanks!
Just curious how long have you had this boat...
Also, 101st?
Fun Times
Re: Serial Number
Serial#: B578319
Thanks!
Sorry But mercruiser did not post the Transom serial number.
ENG# 0B578319, Model# 01651347 MERCRUISER 165
DRV# 0B505473, Model# 01841017 MERCRUISER MC1 1.84:1 gear ratio
Purchased: 06/27/1987
Water Type: OTHER
Primary Use: OTHER
Warranty Period: 06/27/1987 - 06/27/1988
Registered By:
PDI Completed: NO
Date Type Dealer Information Misc. Information
06/27/1987 REGISTERED EXP : 06/27/1988
11/12/1986 INVOICED
Boat Information
Hull Id: RGMB------87 Length: 019
Manufacturer: REGAL MARI Width: N/A
Nbr of Motors: SINGLE Hull Material: OTHER
Model: 195VBR
