sheet metal screw length
barnyard
will be installing toilet (head) on 93 23' larson. Is 5/8" or 3/4" screws Ok for screwing brackets into lower hull for holding tank? What safe length for side hull?
barnyard
or would it be better to use short screws with epoxy?
brand is what every you get from your local boatyard resin supply house.
You don't "screw" anything on a boat. Vibration over time will loosen and cause the connection to fail.
Every thing should be thru-bolted with generously sized washer to spread the load over a larger surface area
