shift cable tool size
sme5
does anyone know what size the socket is for a shift cable tool on an alpha one is
Re: shift cable tool size
Ayuh,.... 9/16" deepwell,.... Ya don't need a Special 1, with the New cables,...
sme5
the kit that i am buying has the cable with the brass bushing from what i understand that is still the old cable is that correct
Bt Doctur
what bondo meant to say is that the newer merc cable are made so the plastic guide tube screws off and you use a regular socket
then screw it back it.If your not using oem cable , leave the plastic tube alone and use a very deep 9/16 thinwall socket or weld a donor socket to one to make a deep socket.
