Shift interrupt question
SteveH_1919
I think the shift interrupt switch (SIS) on my 97 Maxum has bone bad.
When in the water, every time I shift from FWD to N, I blow a 15A fuse and the engine shuts off.
When I re-powered this boat, the GRN/WT from the shift interrupt switch and PUR (12V, which can be traced to the 15A fuse) have a common location which is on one side of the new oil pressure switch.
Here is my thought process.
I read the sticky on the SIS
The shift cable was replaced 2 years ago with no issues after replacing. The boat sat for about a year before re-powering.
When I return to neutral and the boat is in the water, the SIS is overloading the circuit, shutting off the electric fuel pump and blowing the fuse.
I will start the troubleshooting process with the credit card and replace the SIS.
Does this sound logical? Any other ideas?
Thanks,
Steve
Alpheus
Re: Shift interrupt question
No.
GRN/WHT should be going through the switch to black wire (ground) Your causing a short...
Nope,.... Sounds like the Cable again... Did it get Wet during that year,..??
Your wiring sounds wrong as well,... It should stutter the igntion, not blow fuses...
SteveH_1919
Thanks for the replies.
Yes the boat got wet after the shift cable replacement. And I had no problems from the shift cable replacement.
The motor went bad and I repowered.
I agree the wiring sounds weird. I am enclosing a pic of the wiring for the new engine.
The wire from the shift interrupt switch to the oil pressure switch is the WHT/GRN wire on the interrupt switch.
Both of the replies point to a wiring issue. When you start blowing fuses, it is a good indication that there is a wiring issue.
I guess I should call the people I go the engine from and get a clarification, too.
Thanks again.
Alpheus
Like I said you have it wired wrong...
SteveH_1919
Sorry Alpheus...
Maybe I am just being dense, here.
On the diagram that came with the new engine, one wire from the shift interrupt goes to ground (supposedly black).
The other wire WHT/GRN is connected to the purple in the harness, which then connects to the oil pressure switch.
What do I have wrong?
BTW, you appear to be just around the corner. I am in Chesapeake, VA
Thanks,
Steve
Alpheus
That wht/grn wire should be hooked up to another wht/grn wire coming out of your distributer...
That purple wire should not be there. Think about it. Everytime tou hit the shift interrupt switch you are causing that purple wire (+) to short to ground and blowing your fuse.
SteveH_1919
Talked to the guys I bought the engine from.
I indeed have a wiring issue.
Gotta go and see if I trashed the plug i need for the distributor. OOPS.
Trash day tomorrow. Yikes.
More to follow.
SteveH_1919
An inspection of the shop trash cans yielded nothing in the way of the needed plug.
RATS!
So... now I gotta go figure out where to get a replacement plug and find out the wiring of the plug.
Steve
SteveH_1919
SWEET!
I looked in another box and found the plug in question.
Whew!!!!!
OK. Now, I gotta think about Battening down. They have posted Hurricane warnings for the NC coast.
More after dark.
SteveH_1919
Based on a review of the schematics, for every engine I see in the manual, there is not 12V going to the shift interrupt switch.The DWG that came with the new engine is shows 3 wires. The guy at the engine place said some of the shift interrupt switches had 12V to interrupt the RPMs and allow the gears to disengage and some used a ground. See attached.
My switch only has 2 wires. I will presume the BLK wire goes to GND (which it does) and the wht/grn goes to the distributor.
I will also presume my engine uses a ground to interrupt the RPMs. Cuz the 12V blows fuses.
I will hook up the wires for the ground and see what happens when I am in the h2o...after Earl goes by.
Thanks for the advice.
Steve
Alpheus
Its gonna work. There is never no power going through the interrupt switch. Like I said you are causing a direct short every time the switch is closed...
SteveH_1919
It sure worked.
Boat ran great.
