Shift interrupt
Onexl85
looking for some info on adjusting the shift interrupt on my 2001 5.0 efi. It’s a different style then my 97 5.7
Bt Doctur
there is basically no required adjustment for correct operation. In neutral the roller or stem is in the center of the V notch. If you are having stalling/shifting problems it`s usually the lower cable thats causing the problem
Pics will be useful too
kenny nunez
In addition to what the DOC said the switching works opposite from the 5.7. The ignition circuit is broken on the fuel injected systems when the switch is activated versus going to ground on the 5.7.
Onexl85
Here is the switch, the part with the notch seems to move very slightly when shifting. Boat goes in and out of gear smoothly but the switch does not open. I connected a continuity tester to it and shifted forward and reverse and the switch did not change state
Ayuh,.... It won't,.... unless in the water with a load on the prop, 'n then only comin' Outa gear,.....
If it does, at any other time, the lower shift cable needs replacin',....
Onexl85
So when it’s on the trailer the shift interupt doesn’t function?
Bt Doctur
correct , never moves without a load on the prop (coming out of gear in the water)
Onexl85
Guess if it’s not broke.....I better not fix it! Thanks fellas! You guys always come threw with the answers!
Lancer76
Is this truth for all shift interpret switches (i.e., only interrupting with resistance to the prop and only coming out of gear)? For example, could I apply this same 'truth to my mercruiser 233?
Thanks.
achris
More fish than mountain goat
Thanks.
Yes
