shift interuptor switch
renny1
hi guys
my last question before i can launch her (1999 3.0 l mercruiser)
i have just had the new shift interuptor switch installed and everytime it is plugged in it blows a fuse in the main box not the red switch one.is this a bad switch or dodgy wiring somewhere else
Re: shift interuptor switch
What distributor do you have in your engine?
I've read a few of your other posts, and you seem to have a bunch of odd problems. Then there are things like Gen II drive, but a Gen I transom shield. Then you say you have a 99 engiine. Is it just the block that is 99 or everything. Wiring, ignition, carbs, etc.
Too many things not adding up, especially with this new question.
Ayuh,... Sounds like some of the Junkyard dogs I've put together....
Like when asked the Vintage of my current barge, the Best answer I can come up with is,...
It's Mostly 1980s...
Ayuh,... That would be My guess....
renny1
lol it does sound funny when looked on that way Don..
just the engine which is a 99 including carbs wiring loom dizzy etc the only thing left from the old 86 engine is the clocks
the dizzy is a non points one
Assuming that means the Delco EST distirbutor, do you have the OEM service manual for it? #26 is the one you want. (see the Adults Only sticky if you don't have it) Then compare your wiring to how it should be.
There is no way just plugging the shift interrupt switch in can blow a fuse.
Still not sure what this main box is, and have to guess the red switch one is the circuit breaker on the engine.
jtybt
Could be a combination of an old style interrupt switch which grounds the primary ignition circuit connected to bad primary wiring and grounding the ignition.
